hi im in need of help very urgently
im djing at a party tomrow with my computer set up and i need to no what leads is needed to hook my computer up to a amplifier
if have a jack that connects to the output of my computer and on teh other end into red and white rca, but when i put this into my small stereo to test out it sounded very low and couldnt hear much
would this be because of teh stereo im using?, the lead?, or the computer?
or is there something else i could buy to use instead ..?
thankyou so much
thankyou so much
Posted Fri 11 May 07 @ 1:59 pm
Typically, most of us go into channels of nearly any type of mixing board, then from the outputs of the mixing board to the amplifier, then to the speakers.
Posted Fri 11 May 07 @ 3:55 pm
What sound card do you use? It is known that sound output is low on internal sound cards and you will need some external mixer to pre amp.
Posted Fri 11 May 07 @ 4:21 pm
