VDJ does not work with the ttm57 but it works with the sl1 box. Are there any plans to make it work with the ttm57 in the near future?
Posted Thu 10 May 07 @ 8:21 pm
Rane has prevented that mixer from working with other DJ software
So it cant work with VDJ, unless some sort of "hack" is applied
Posted Thu 10 May 07 @ 8:35 pm
even though that the drivers for it are public?
anyone have the hack? ha
Posted Thu 10 May 07 @ 8:50 pm
Tell Simon to hack it LOL :))
Posted Fri 11 May 07 @ 1:05 am
We need someone to come up with a "crossfader start to MIDI converter" so we can use the crossfader to control vertual dj and not have to go out and buy a $1000 mixer just because it has midi.
Posted Fri 11 May 07 @ 8:43 am
Is that possible to do that KregCZ? to make a crossfader start to midi converter and use a regular mixer?
Posted Tue 15 May 07 @ 4:48 pm
technically, as long as it has a variable voltage (volume) difference over the crossfader (unlike digital faders), then it should be possible. Different voltages could be converted into a MIDI crossfader position
Posted Tue 15 May 07 @ 6:30 pm
its probaly in the firmware , some where to simply drop the usb connection on other softwares
Posted Tue 15 May 07 @ 10:56 pm
I would think that you could take the fader start siginal run it to a some small device that would sence the signal and convert it to midi.
Midi's been around about 20 years, I think someone could be smart enough to do it.
If someone can convert a usb game joystick to a midi controler, then someone should be able to convert this simple signal from the fader start.
Posted Wed 16 May 07 @ 5:08 am
