Forum: Old versions
Topic: sound quality
One question about the sound quality;
When playing very beginning of the song “Girls - Beastie Boys”, pitch up. the sound is terrible. Will a better sound card cure this type of issue..??
Posted Sun 06 May 07 @ 4:32 pm
Not really sure what you are talking about but better PC with the more power can improve sound quality using Keylock.
This is what I'm running.. Why pay all that cash for an expensive card, what do you really get out of it?
Motherboard
Asus P5B Intel P965 Chipset, LGA775 compatibility, Intel Core 2 Duo and Extreme CPU support, Intelligent Overclocking Tools, PCI-Express x16, Gigabit Ethernet, SATA, 8-channel Audio, USB 2.0
Processor
Intel Pentium® 4 631 Processor Prescott 3.0GHz, 800MHz FSB, Socket 775, 2MB
Ram
OCZ OCZ28002048ELDCGE-K 2GB Kit DDR2-800 PC2-6400 Enhanced Latency Gold Edition Dual Channel Memory
Video Card
Sapphire Radeon X1600 PRO PCI Express 512MB DDR2 Video Card w/TV-Out, DVI & VGA
paulettecerra wrote :
Processor
Why did you took this processor, you should take Pentium D 915 Dual Core for a 20-30 Euros more? I also recommend the new one Core 2 6420 with 4Mb cache, it is the best for the money now for sure!
Which sound card do you use, Maya?
Onboard card,, I had a 955xbk Intel board that went bad so i went with the asus.. So, If I'm not scratching the sound card isn't that important?
Well no, but ordinary Sound Blaster Live 24bit USB has much better sound and dynamics IMHO and it is around 60$, if you can find it.
And I must disappoint you, most of dead motherboards in my Pc shop/Service are Asus :/ Asus has dropped it's quality in my experience. I suggest Microstar or Foxconn motherboards.
So, will a better, more expensive sound card help solve the above..?????? I really hate to lay down a couple of bills for something that will not help…
Probably it will, if you can try before purchase will be nice ;)
