I burned the time code to a cd in slow burn speed and then hokked up my cdj-1000 to my soundblaster live soundcard. The appears to be a small amount of delay be tween the time I press on the disc and the software stopping the song when compared to clicking the mouse on the disk.
Is there a way to fix this?
Do I need a higher quality soundcard?
I recently had the chance to demo the competeing software that has the external box you plug the turntables into and there is not a noticable time delay.
Posted Sat 18 Sep 04 @ 8:59 pm
It's better with ASIO drivers but with a Sound Blaster Live Sound Card you can't install this drivers. So it's normal that you have a small delay when you scratch on your CDJ-1000.
Sorry for my bad English :(
Aurélien
Aurélien
Posted Sun 19 Sep 04 @ 12:58 pm
