HI, hope someone can help as I want to get this sorted before I purchase this.
I have a lot of music on an external Hard drive (mastor 200gb USB 2.0))
Basically i'm scanning the external hard dive, its picking up all the tunes & playlists which are from itunes but when I then try to play a song by going to one of the itunes playlists & dragging it on to the deck it just keeps giving me an error message?
Vj is playing all the songs from my internal harddrive fine its.
Any help greatly appreciated
Posted Fri 04 May 07 @ 5:42 pm
Wild guess - I don't use iTunes: VDJ can't read iTunes playlists?
I know for sure that WinAMP playlists works, and the internal VDJ generated playlists. By dragging the .m3u playlist file to one of the decks, it loads the first song(s), and puts the rest in the right playlist bar.
Posted Fri 04 May 07 @ 8:09 pm
Posted Fri 04 May 07 @ 9:06 pm
Ok, it isnt just through the playlists it wont play a track. Even if I go straight into the directory where the music is on my external hard drive it still wont play them??
Its scanning & finding them but wont play them, any ideas anyone??
Posted Fri 04 May 07 @ 9:39 pm
VDJ can't read the ACC format that ITunes uses. You will have to convert the library to MP3 format or another format VDJ can read.
Posted Sat 05 May 07 @ 12:50 am
