I recently purchased the Hercules MK 2 controller. I know that if I install Virtual DJ software, the Hercules drivers will be part of the installation. However, if I purchase and install Numark CUE, how do I get the Hercules driver? I'm using XP. Thanks...
Posted Fri 04 May 07 @ 7:16 am
heya add your console serial here to get free addons and updates
http://www.virtualdj.com/fusers/modifuser.html
the drivers are downloable from the hercules website , or here in the hardware forum.
they are the same for home or pro you can get a
discount aslo if you add your serial
Posted Fri 04 May 07 @ 11:11 am
