i just got VDJ4.3 and i ordered the BCD300 which isnt here yet fgiured id give it a try(may change it for a total control or M-audio torque xponent if the behringer isnt upto par)but i wanted to buy the trigger finger and use it to control the samples and other functions. will this work and how do i go about connecting it , using and programming it. do i just install the drivers plug in to usb port and thats it the controller and the trigger finger work simultaneously. please if anyone has any info or links to this i owuld appreciate it
thanks for all your help very imformative site
Posted Fri 04 May 07 @ 1:37 am
add your serial to get pro level benifits :)
http://www.virtualdj.com/fusers/modifuser.html
the two can work together
you would need to map it on the remote control tab on midi options
Posted Fri 04 May 07 @ 12:21 pm
ok ths so all i have todo is select the midimoption and plug in the TF i dont have to open anyother programs ?
thanks
thanks
Posted Fri 04 May 07 @ 5:53 pm
indeed :)
Posted Fri 04 May 07 @ 6:30 pm
i just recieved the trigger control but i can only get 1 pad to play one sample can someone help me out on how to preogram it
thanks
thanks
Posted Fri 11 May 07 @ 11:50 pm
