Outside of the Ecler - Nuo4 and the Pioneer - DJM 800 Mivers.
Is there other mixers that will also work with VDJ not including Hercules.
Reqirments: 4 Channels, 2 Mic outputs,Midi, 10" or 12" width size.
Posted Fri 04 May 07 @ 12:32 am
You'll find it hard for 2 mic inputs/outputs. Don't think there are any.
Posted Fri 04 May 07 @ 1:48 am
Allen & Heath...
if you can afford it
Posted Fri 04 May 07 @ 2:04 am
