i find that when i use the faders and the volume knobs etc, i get a fairly audible sound coming out of the speakers. This is definetly from virtual djs faders etc.
Anyone else have this problem?
Its sucks too because you can notice it when you record a set and put it on cd.
Can this be fixed?
Thanks.
Can this be fixed?
Thanks.
Posted Wed 02 May 07 @ 1:33 pm
It is performance issue, try lowering performance tab in settings and untick safemode and overclock and try it.
Posted Wed 02 May 07 @ 2:36 pm
i´ve got the same problem... though i can´t imagine it´s a performance problem ?!? dualcore 2.8ghz... lol ... i´ll try the slider.
edit: i tried it, the faders are clicking free, but my right deck is skipping !!!! the sound is crazy, the left deck is unaffected...
Posted Sun 06 May 07 @ 2:26 pm
Than maybe it is a driver issue, try different driver for your sound card or a clean install of VDJ.
Posted Sun 06 May 07 @ 4:30 pm
I tried to overcome the problem by installing a fresh version of virtual dj but the shuddering sound still exists.
By the way thanks for all the help.
....I cant see it being a driver issue because i have tested both the onboard soundcard in my laptop and i also have the new "conectiv" soundcard interface by M-Audio and i stilll get the same sound on both sound cards.
Any ideas,
Thanks
Any ideas,
Thanks
Posted Mon 14 May 07 @ 1:33 pm
Try lowering performance tab and enable Safemode.
Posted Mon 14 May 07 @ 3:06 pm
Hell yeah that worked perfect, by lowering peformances tab you mean put towards "best quality" or "fastest"?
Sound seems to be completely gone now though!
cheers heaps.
cheers heaps.
Posted Mon 14 May 07 @ 3:50 pm
To the left to be "Fastest" on performance.
Cheers mate ;)
Cheers mate ;)
Posted Mon 14 May 07 @ 4:30 pm
Cheers bra.
Its all working perfect, just how i wanted it! ;-)
Posted Mon 14 May 07 @ 5:00 pm
i have the same problem... but i don't have the safemode option ...
Posted Tue 15 May 07 @ 9:13 pm
That is because you use Home version and Safemode is only in Pro version 4. You can try demo and see if it is working for you.
Posted Wed 16 May 07 @ 12:04 am
