Forum: Old versions
Topic: TCCD and ICDX problem
I have been trying to use the Virtual DJ timecoded cd's with my ICDX's, however i can not seem to get more than a 5-10% signal. I have tried switching the wires, thinking that maybe it was something with the soundcard, but still, barely any signal. Is it something with the Time coded CD? I had read a long time ago that problems with signal may be due to decibal level or something. How do i rectify this problem, because I REALLY don't want to drag my ICDX to clubs all the time, but would like to start also using the Time coded Cd's
PS- I already burn the cd's as audio cd's if anyone is thinking that is it
Thanks in advance
Posted Tue 01 May 07 @ 3:17 pm
Why do you want to use Timecode cd's when iCDX is the midi controller that is fully supported by VDJ? Just enable it in Remote Tab in settings and you are ready to go!
i need to have use of TCCD'S when i have to do club venues in which I cant bring my ICDX's. I am trying to first get a set of TCCD'S to work with my ICDX.
Aha. Well, did you enabled your inputs on your sound card, check it out in Recording settings of your sound card. Maybe it is not selected or the volume slider is all down.
