Hello everyone, new to the forum and software. I figured it would be wise to derfrag the external HD that contains all my MP3 files before i started using VDJ on the road, but when trying to do so i get a " CHKDSK /F error"
I can't figure out what this is for the life of me. Anyone else encounter this before and is so what was the fix?
Any help would be great.
Thanks, Alex.
Thanks, Alex.
Posted Tue 01 May 07 @ 4:00 am
it's "chkdsk /F C:" to defrag the partition C:
Verify the letter for your external hard drive
Posted Tue 01 May 07 @ 4:05 am
So, after nearly bashing my head on a the sharpest object in my house and ripping what little hair i have left out a answer arises in mere minutes .
THANK YOU - I SHOULD HAVE SWITCHED TO VDJ SOONER
Posted Tue 01 May 07 @ 4:09 am
As you see, it's never too late ;)
Welcome to the VDJ world!
Posted Tue 01 May 07 @ 1:55 pm
Also be careful with external drives and Windows. Make sure that you either shut down Windows completely or eject the external drive before removing it from your system. (Right click on the drive under MY COMPUTER, and select EJECT.) Unplugging the drive while Windows is using it will cause data corruption. (Which might have been the source of your CHKDSK message.)
Posted Tue 01 May 07 @ 3:40 pm
Thanks for all the help.
Posted Tue 01 May 07 @ 11:54 pm
