When i'am trying to mix two songs, the songs are not playing perfect, i'm hearing ,,white horses''.I am using sync button and i see that two songs are playing synced but sound like not good.I'm playing original mp3 with flat rythm.equalizer can't help me too.Maybe its pc performance problem or vdj????My pc: Amd sempron 2800+ 448MB RAM, HDD 160GB
Posted Sun 29 Apr 07 @ 12:36 pm
The anylizer does not always hit the beat in the right place, the right BPM just not the right spot in the song. I.E. you might be hearing the first track and when mixing the second it is say a 1/4 beat off where it needs to be so the mix sound bad. I believe there is a used guide you can look at in the Help section give it a look and it might answer some of the questions you had from the other post as well.
Posted Sun 29 Apr 07 @ 4:00 pm
But i can't mix anything.There is no track that I can mix to another track. Even example tracks ,,Open'' and ,,satisfaction'' doesn't mix'es perfect.
Posted Mon 30 Apr 07 @ 10:59 am
You cannot count on that AutoSync and BPM feature to be perfect. Some songs do require a "hearing touch." There are even some, where it fully needs your ear for tempo and beat matching where the AutoSync doesn't work at all.
ALSO by the way, try going in to the preferences and there should be an option to change the of music you want it autosync (ie house & any music) .... Change it to any music. That might help.
Posted Mon 30 Apr 07 @ 2:43 pm
Maybe I have to low RAM? I have 448MB, Minimum:512MB, Recomended 1GB
Posted Mon 30 Apr 07 @ 3:40 pm
Posted Wed 02 May 07 @ 6:47 pm
First of all, don,t let the computer control u, U ARE the one in control, This software is great and features a lot of helping hand to the DJ in control. The BPM is not always correct as they seem to be n thus need some pitching when mixing. Basically Any song can be beatmatched if it is within the same range n if u cue it from the first beat, it would be best as a song is merely patterns (measures) of rhythm n once u get it right, u can mix well.. Thats the basic.And secondly.......keep practicing n best of all try to start by hearing rather than see the wave flows..:) . It helps if ur computer breakdowns:)
and lastly yah, if possible, do upgrade ur ram ..at least 512 GB..
Cheers
DJ Antares
Posted Wed 02 May 07 @ 8:26 pm
