Forum: Old versions
Topic: Problems with headphones on decks
I have a Hercules MK2 controller and it worked perfect. But since i have upgrade, my headphones don't work. I can't listen to different decks any more,... well, there is no sound coming out of my headphones! Only when i switch to "Mix" i hear something!
Posted Thu 26 Apr 07 @ 6:09 pm
I have the same problem!! for some reason i cant hear channel A or B any more!! only Mix & Split.
But split dosent work properlly eather... Does anybody no any solutions Please! Would be helpfull.
Water
what versions do you use?
i have the same problem.. i use cracked 4.3
After upgrading the drivers for the mk2 it worked for me.
On Sound Config choose
outputs: headphones
Card: mk2
Outputs 1/2 main 3/4 headphones
i hope to see you all as full pro users soon
Draz you said WHAT???? I am sure this issue ur havin is due to the crack!!
To the top 2 posters which version driver are you usin for the MK2??
Might work better if you upgrade to the Pro version, top two posters.
As for the crack - most cracked software could do harm to your computer.
I have a minor problem with getting the headphones to work - you sometimes need to turn the knob pretty fast.
I can get the mic (it's a headphone-microphone I'm using - bought at PC World) to play through the speakers - I don't know what I did, but last night, I managed to get it to play through the headphones, too - except that I have to open the left fader to hear it.
How do I set it so I can hear the mic through both speaker and headphones without having to open up the fader.
Thanks to somebody on here, I've managed to work out how to cue up records without "broadcasting" it.
I use the Fader Start plugin to good effect, too. Had minor teething troubles with the more recent version - but it just came to life, as it were! Click on the CF buttons and you can use the left-and-right faders to start the song, instead of the crossfader.
try changing to 2006 drivers. It more stable.
