I've just installed the February DirectX release (included with the SDK), and when I activate the plugin I can't see the underlying video :$
Posted Thu 03 May 07 @ 3:54 pm
Yes do not use the SDK version
Posted Thu 03 May 07 @ 6:08 pm
SO, which version should I install? A previous one? If I remember well, you've always talked about an August 2006 version to get well...
Posted Thu 03 May 07 @ 8:26 pm
You have to install the runtime version and not the sdk
Posted Thu 03 May 07 @ 8:45 pm
You have April 2007 version of Direct X, try that.
Posted Thu 03 May 07 @ 9:29 pm
I just realized you can still use the other text app, at the same time. I am so happy, I am touching myself. Wait a minute, I have 10 dancers here, let me get some help. I'll be right back.
Posted Thu 03 May 07 @ 11:17 pm
What about a preview window
Posted Fri 04 May 07 @ 12:40 am
lol @ Rick
you poor thing....you got the life mon
Posted Fri 04 May 07 @ 1:02 pm
Lol Rick style all the way :)
Posted Fri 04 May 07 @ 2:33 pm
i had crashes also ........ 1 over the weekend at a communion .......i froze during the first video .........i was running traktor plus vdj when i rebooted it went into setup ??????????? i just exited with no changes .......then i just played no more video ........... i used my backup system for a couple songs at first then switched to the lappy w/o video ( until the woman who hired me unplugged my system by accident .......then had to reboot EVERYTHING ) then the venue blew a fuse .........ever have one of those gigs ???????
i have been attributing these freeze ups to 4.3 however ............if i use 4.2 and the great new text plug in all is fine.........
but 4.3 has problems ......or is it just me ????
Posted Fri 04 May 07 @ 2:48 pm
There was no change in the video between 4.2 and 4.3 so it's just you ;-)
Posted Fri 04 May 07 @ 6:38 pm
i just tried to jam it up and it didn't , so i can't account for it ........
i put a small playlist of vids on automix , then launched traktor while it was playing ..... no probs
now i have traktor on auto and vids are fine ........
now i'm ripping with audio grabber and typing this...... no probs
now i hook up my bass o matic ....... no probs
well i'm stumped ; anywhoo all seems fine
Posted Fri 04 May 07 @ 10:30 pm
What is the deal with "Direct 3D not initialized"? I have three machines and all three give me this error when I try to run the new "Beta3". I had no problems with the first Beta. I have installed Feb 07 direct x.
Rusty
Rusty
Posted Fri 04 May 07 @ 10:54 pm
Rusty
Rusty
You have to hit the activate tab "before" you activate the plug in. In other words, it has to be on in your effects module.
Posted Fri 04 May 07 @ 11:38 pm
Thanks, that did it!
Posted Sat 05 May 07 @ 7:09 am
The text 2D window doesn't ALL show up on the skin. The lower part of the window and the right side isn't complete in the window. How do I remedy this?
Posted Mon 07 May 07 @ 3:56 pm
What resolution are you using?
Posted Mon 07 May 07 @ 7:20 pm
Yes i'm working on auto-resizing. I built the plugin with the default skin ;-)
Posted Mon 07 May 07 @ 10:50 pm
Ok, that explains that, another question though?
Sometimes I cannot use the keyboard for music search thru the folders when this program is running?
Has that been reported yet? Letters don't appear after hitting the keys? Weird?
Posted Tue 08 May 07 @ 3:06 pm
Every once in while, I have the same situation. I just mouse on the text box again to have it recognize my intent.
Posted Tue 08 May 07 @ 7:58 pm
