directx sound driver error .....?????
Why am I getting this directx sound driver error message ? I was running last night and I didnt change anything. now today on start up I get this???
Posted Tue 24 Apr 07 @ 11:01 pm
What kind of sound card are you using? If USB, did you plug it back into the same USB port as you used last night?
Posted Tue 24 Apr 07 @ 11:25 pm
i think if you look at your sound card settings you may just have to reset them to the enviroment your in now and not the club setup ie:- inputs/none, outputs/single output, sound cards/simple, sound card / yours systems hope that helps...Tayla
Posted Wed 25 Apr 07 @ 1:00 pm
