hey guy's
so i bought my friends whole system from him since he needs money for a house...but he as VDJ 4.2 and i am used to working on VDJ 3.4...ok so How do i lock the beat match? i know on 3.4 you just right click it and it stay's light....i need the most help about that. and how do i set it so i will get the BEST audio quality and speed with using my MK2? when i move the volume knobs and pitch i get static like noices in my head phones and also when i have my headphones on mix it is ok BUT when i out it on A or B i get NO sound from my head phones...i am very confuzed an now geting frustrated can some one PLEASE HELP ME FAST i have to so a school dance tonight...please help me.
Posted Tue 24 Apr 07 @ 2:05 am
unfortunately he cant dirrectly sell you his licence acording to the eula
so you should buy a new copy of 4.2 or use 3.4
you could try to ask to move his purchase to your acount
contact
as to the problems go to options >
"performances"
choose fastest
"autolatency"
and press ok.
contact
"performances"
choose fastest
"autolatency"
and press ok.
Posted Tue 24 Apr 07 @ 10:18 am
Here's a tip. Never, ever, change anything, just before a gig. If 3.4 is working for you, use it. You clients should not be beta testers, for you and some new software, that you can't use.
Posted Tue 24 Apr 07 @ 10:02 pm
Yeah, you only have to learn once that last minute changes are big no-noes!
And beatlock was always something i disliked, i like being in manual control of syncs and everything cause the lock feature used to crap out when the bass spike didnt match the beat grid :/
I suggest you practice doing it manually cause its a lot better in my opinion
Posted Tue 24 Apr 07 @ 10:05 pm
A Man... I think the guy said he was USED to using 3.4 but he got the system from his friend who was using 4.2r1.
I know I missread that at first too.
Posted Tue 24 Apr 07 @ 10:30 pm
I would not use anything that has more then two buttons on it, if I just got it today. Learning how to use equipment, on the job is a no no.
Ok well...i ended up using my 3.4 and i still have not found out how to use beat match on 4.2 and i got evreything else figured out and what are the lock things???? the keylocks?! and what are the other things that are on 4.2 that are not on 3.4???....and how do i use the video thing? how do i put videos? just drag a clip in the deck and play?
Posted Thu 26 Apr 07 @ 3:16 pm
ARMADA
Please reconsider what you are doing here.
Your "friend" has given you a cracked version, actually 2 cracked versions, a 4.1 and a 4.3 version.
Everyone you see here as a pro version user has had to purchase the software including the Teamers, I own 2.
So please respect them and the developer of this fine program and get yourself a legit copy if you like it enough to use it to the fullest extent.
You actually get a discount for being a MK user.
The terms of use prohibit users from transferring ownership under any circumstances.
The Pro version comes with a detailed user guide that will answer all of your questions also.
We hope to see you as a Pro Version user soon.
Posted Thu 26 Apr 07 @ 4:06 pm
