Forum: Old versions
Topic: x-session midi mapping help!
Help!
Everytime I try to change parameters in the midi mapping section, the [value=0] box changes to a [relative scale=0] box
how to a set it to leave it at [value=0]??
thanks!
Posted Wed 18 Apr 07 @ 3:47 am
ok - got that part sorted (i think)!
BUT
does anyone know how to map the pitch blend buttons +/- to the buttons on the X-session?
I tried, but it ended up doing some weird things, like permanently holding the pitch + down (even though i selected temporary), and not working for the - pitch
help!
I'd love to know that, too. I have the X-session pro and i was unable to map for pitch-bend.
anyone? :(
wow, i can't believe no one has the answer to this question!
Final plea! Anyone?
Sorry, I use the X-session but it don't use it for pitch bending... I will try to map it out and see if I can help...
Joe
go in config, enable midi click config, load midi_xsession. then find (cross fader ) move the cross fader back and forth and it should pick up the signal...them push ok and go check and see if the fader moves on the screen. The part i'm stuck on is the headphone part. How can I hook my head phones up?
