Whats up everyone. I downloaded the trial version of VDJ and connect everything. I burned timecode and everything seem to be working fine. I'm using 2 denon 3500 and numark mixer with M-audio torq conectiv.The one problem I'm having is, the one cd player is playing backwards. I have to press the reverse button on the cd player for the music to play normal. I changed cd's because I thought it was how the cd was burned, but didn't work. I'm using nero and beurned at 16kbs. what am I doing wrong?
Thanks
Thanks
Posted Wed 18 Apr 07 @ 1:53 am
Look at the "record" in VDJ on your screen, below it is a couple of arrows. Try flipping it the other way.
Posted Wed 18 Apr 07 @ 3:30 am
I tried using vdj without timecode just straight through laptop and evrything is working fine..
Posted Wed 18 Apr 07 @ 12:31 pm
sounds like the timecode signal is to loud try
reducing the volume of the mp3 by roughly 13 db then burn another cd if this is still to loud lower it more and burn another
some cd players are very loud and this overpowers the software.
if you dont have editing program try audacity its good free one
good luck :)
good luck :)
Posted Wed 18 Apr 07 @ 1:02 pm
actualy it should be 0 db !! maybe you did some mistakes on connecting your decks, or just go to softvare menu and try to change something
Posted Wed 18 Apr 07 @ 1:21 pm
whats funny is when nero asks you how many copies i put 2. One works and one doesn't. I'm going to try to burn another one.
Posted Wed 18 Apr 07 @ 10:47 pm
