Forum: Old versions
Topic: MP3s Not loading. - Page: 2
djcelPRO InfinityModeratorMember since 2004
Is it CBR or VBR mp3s?
Posted Fri 27 Apr 07 @ 6:44 pm
On the Services and Process I end task on stuff i dont need, but i do not have much since i reformatted it about 3 weeks ago and did not install anything but xp and vdj. How do i check to see if the MP3s are CBR or VBR?
Posted Sat 28 Apr 07 @ 12:01 am
sbangsPRO InfinityMember since 2004
right click on a file and press properties should say so here
aslo you can check in the program you riped them in or the site they came from
Posted Sat 28 Apr 07 @ 12:09 am
Believe it or not but i clicked on a few of my mp3s and in properties it does not say if the MP3s are CBR or MBR. I checked winamp and music match and still nothing, music match is what i use to rip the MP3s.
Posted Sat 28 Apr 07 @ 2:44 am
check on the config of music match to see what they have choosen for you
Posted Sat 28 Apr 07 @ 3:31 pm
Ok in music match, my music is not set up to rip using custom VBR. I have my MP3s Ripped at 160kbps. VBR or CBR are not selected. That is why both CBR and VBR are not showing up in the properties of the MP3s or when i play the MP3s it shows 160 or 128kbps. Can that be the reason why my music is not loading right?
Posted Sat 28 Apr 07 @ 5:51 pm
constant bitrate is better it loads faster
Posted Sat 28 Apr 07 @ 7:04 pm
To do constant bitrate what program is recommended to convert what i already have? Also what percent should it be? Thank You
Posted Sat 28 Apr 07 @ 11:17 pm
SkyFXL, I check on the CBR conversion and what i found was my MP3 should have been ripped to CBR. There are only 2 ways to rip and that is VBR and CBR and my MP3s were not selected to be ripped at VBR rate. My MP3s are 160kpbs quality and i do beleive it is at CBR rate. Unless there is another way to check. Is there a better program to check to see if it is CBR or VBR? When i play my music in either Winamp or MusicMatch all it says is 160kbps and nothing else. What is recommended for cd ripping to MP3 and will it let me choose VBR and CBR? I use music match to convert my files but would to know what is better and user friendly because then i will have to do all my MP3s in that format (CBR) if it not not already done so. I have about 47gigs of music that i would need to convert. Thanx in advance
Posted Sun 29 Apr 07 @ 7:06 pm
personaly i just use windows media to rip at 320 kbs mp3
i will try to find more info i aslo advise you to make a support ticket
on the issue to see what the team think
support
Posted Sun 29 Apr 07 @ 7:22 pm
Posted Sun 29 Apr 07 @ 7:35 pm
Ok Thanx, I submitted a ticket, do you recommend converting songs to 320kbps or should i leave them as 160? 320 would take up alot more space, would it really make a difference.
Posted Sun 29 Apr 07 @ 8:09 pm
gota leave them at the bit rate they are cant put back what isnt there :)
Posted Sun 29 Apr 07 @ 8:18 pm
