Greetings to all :0)
I've only had my Hercules for a few weeks and the only thing i don't like is that you can't adjust the mix/fade of each tunrtable in your headphones (the way you can with a mixer and vinyls/cd's) a mate has a beringer (or what ever its called) mp3 desk and this has a seperate dial for fading/mixing turntable 1and2 in at different levels.
is there anyway i can achieve this with my Hercules?
Posted Sat 14 Apr 07 @ 6:54 pm
add your serial to get home level benifits :)
https://virtualdj.com/fusers/modifuser.html
you can listen to seprate decks using the headphones by using the headphone selector if you are using the mk2.
Posted Sat 14 Apr 07 @ 7:11 pm
