I bought Serato Scratch Live Over a year ago. A friend of mine let my play with his VDJ. Between the effects and pitch adjustment, and sampling i really like VDJ. Is there any plug-ins or settings that can Sync VDJ With my Serato Hardware?
I would like to know before i go and spend the money right now on VDJ.
And i also read in one of the post that the Virtual Vinyl for VDJ is not out yet. Is this Correct?
Posted Fri 13 Apr 07 @ 7:31 pm
you can use the sl1 box with virtual dj and virtual dj timecodes just like a normal card.
Posted Fri 13 Apr 07 @ 7:33 pm
these are specs with the ssl box
http://www.marxpro.com/vdj
Posted Fri 13 Apr 07 @ 9:55 pm
Latency = "512" in VDJ Config ??
I advise you latency = "auto"
Posted Fri 13 Apr 07 @ 11:10 pm
using that config was the best with that setup....using that hardware. I only had that setup for a week to demo it with serato. I use the delta 44.....which is a much better card.
Posted Sat 14 Apr 07 @ 12:52 am
if you are using Serato, it will not work on vista, so if you are looking to use vista, wait for the new stuff comming out to use your VDJ, 3-6 mo will make a world of diffrence
Posted Sat 14 Apr 07 @ 12:13 pm
Serato SL1 box now works under Vista. I just did a fresh install and tried it with the new 1.7.2 vista drivers.
Posted Wed 25 Apr 07 @ 7:40 am
I have tryed using my SL-1 with VDJ but cannot seem to get the timecode cd's to steadily read 100%. It drops down to 30% then back to 100% and so fourth. Anyone have any ideas? Setup is CDJ-800's.
Posted Fri 27 Apr 07 @ 6:51 pm
