i just dl virtual dj n when i try 2 open it ...it says the skin ur trying 2 use has a higher resolution then ur screen wat can i do?
Posted Wed 11 Apr 07 @ 10:53 pm
Make sure your system is set at 1024X768 as that is the default.
Posted Wed 11 Apr 07 @ 11:15 pm
cracked :DD about skin just press ok :}}
Posted Thu 12 Apr 07 @ 2:20 am
