Forum: Old versions
Topic: do you have problems ripping & converting dvds
think this may help everyone like me that has initial problems ripping dvds to mpeg or any other format your problems are now over this programme is tayla proof meaning any idiot like me can be ripping dvds or individual tracks in seconds.
you find this programme at www.avsmedia.com and choose avs video tools its on special just now at roughly £22 OR 39.95 USD its a 4 in 1 bundle of programmes and is free to try with their banner coming up if your track is over five minutes long. i've been using the video remaker part, all you do is bung in the dvd select your source (what you want to copy) chose whether you want to rip and convert the full dvd or select individual tracks, select copy to dvd or mpg2 and bobs your aunty perfect video and audio in one easy go, i've been ripping individual tracks in less than thirty seconds give it a go its FREE on demo...enjoy.....Tayla
Posted Wed 11 Apr 07 @ 9:51 pm
Just bought it, he's right. You won't be disappointed!
cheers bryan
thought i had wasted my time giving good info out even if theres only one that uses the info its been worth it... and dont forget you lot its free on demo...Tayla
Why would we not use the Rip DVD function that comes with VDJ? It seems pretty easy.
shit wished you had posted earlier, never tried, sorry, must have something to do with the full instruction manual that i did'nt get, it if its that good why so many posts for "ripping software" on the forums?....Tayla
It's because it aint great! To be honest I wish VDJ would remove the ripping option, it's flawed and doesn't ripp all music dvd's. Why try and be a jack of all trades instead of devoting your time to being a master of one?
A dedicated ripper is far superior. For anyone who wants some options, take a look at the tutorials in my blog.
tophouse how you doin'
take alook at this programme see what you think and tell me if its not the easiest ripping software you have come across you dont even need tutorials with this its so piggin easy...see ya
Tayla,
One question on AVS though? How do you make a DVD, on DVDtogo, it has about a dozen options, and one of them is DVD player with XVid capability, but what about just regular DVD players; you know the mpeg2 type on plain ole DVD players. How do you make a DVD that will play on ALL DVD players is my question?
the one i've been playing about with so far is video remaker after you have chosen the file or files you want to copy you have a drop down option which lets you chose either dvd or mpg2 i have only chosen mpg2 for my music files so far, waiting on my reg key to come on e-mail have'nt tried any others yet have ago on that just now and i'll have alook at dvdtogo we maybe able to help each other out...ain't got much time tonight getting sorted for tonights gig but if i can't get to it tonight will take a look see tomorrow...Tayla
just had a quick look at dvdtogo your right about xvid, use video remaker it converts straight to dvd hope that helps ya...Tayla
Where does it say to load the file 0(say mpg) and burn to disc? Couldn't find that anywhere?
hi bryan
this is the route i take after putting in the dvd, open up video remaker, at the top right hand corner left click where it says add files, it comes up with a selection of where to chose a file from mine is cd drive D.
audio ts & video ts will come up double click video ts, after that the screen will show vts-01-0 double click that wait a couple of seconds until they load in the main window of source files, on the left hand side there are four options chose the one that says detect scenes you'll see that each track is there in my case fifteen, until you get the hang of it for the tracks you don't want left click then press delete until you have the selection you want, at the bottom right hand corner it says REMAKE NOW left click that,a box will come up with a header "save file" on the output section where it says name chose a title for your file/s or what the video is called, Path, that is where it has basically decided to store your file you have an option to store it eleswhere in the drop down window to the right.
SETTINGS
press the button on the right and a drop down window will give you an option of either dvd or mpeg2 the choice is yours, after selection press start, there you go, hope everything has gone alright if not pm me and we'll take it from there...Tayla
looks like a v good ripper
hi davefromlondon
glad you took a look at the software, now is'nt that the easiest piece of software to rip dvds that you have come across, with no direspect to anyone on these forums no one ever again needs to go out searching and then digesting someone elses tutorials on how to rip dvds they to me are now consigned to the waste bin they just need to get them selves a copy of the software (buy it guys) and all their worries will be over in seconds no need to follow someone elses instructions on this subject ever again the whole package is so self explanatory, if i can use this real easy to follow software anybody can...
Tayla
Tayla,
I burned to 2 dvd discs from vob files ripped from the camera's minidiscs.
Disc one had audio/video out of sync problems. Disc two was fine.
Any idea on what happened here?
I was hoping the program was flawless!!??
hi bryan how ya doing
the only thing i can think of and mind its only a guess were you running something else while doing the first file coz when i first started out i was told make sure when burning don't run anything else in the background, as for the programme being flawless upto now the programme has been ok for me but i would'nt treat any software as 100% without its cliches you just got to be patient and we'll get to know about them sooner rather than later lol, try running that first file again by itself and get back to me and let me know how you got on...
Tayla
