The 'track progress meter' under the turntable, where the cues marker sit :
I am used to the vdj v3.x version which I can predict the break of the songs. I think vdj4.x version gives less information. (The break can has loud beat so the wave form may be same as the lyrics part)
The "track progress meter" is already very very good, why change / bend it ?
Since the default skin comes with vdj4.x is already using the new meter, this make me think vdj4.x the program itself has changed and comes with it as default.
rprado
rprado
Posted Wed 11 Apr 07 @ 5:03 pm
you can disable it in the skin ;-)
Posted Wed 11 Apr 07 @ 8:43 pm
