Topic: Mike not working on MK2
Hello,
i have the Console DJ MK2 and no way to make the microphone work.
I push the button, control the level, but no way. I checked the settings in the effect and level, but still nothing.
I went to the shop and changed the console, and it still not work.
The same mike works fine on other hardware.
Please tell me what should be set to turn the mike on ?
Posted Sun 08 Apr 07 @ 6:32 pm
is it a condesnser ?
Did you try going in to the Sounds Control directly through windows to make sure it isn't on mute? When you do that, from the drop down menu, make sure you have the Mk2 device selected. -- I may be wrong about that or...
OR make sure that the option is turned on through the Mk2 control panel... Should be a little picture of CD and it says DJ below in the task bar bottom right. Double click it and it will bring up the panel... Check the volume settings there too
NOTE: When I use to use the Mic through the Mk2, I would have to turn it all the way up to hear.
"Mike not working on MK2".
Who's Mike?!
Oh, I see... you meant "Mic". ;)
- VT ConQuest
(Visual Turntablist)
