I played around with my set a few times an realized a bit of lag running with ASIO using the best configuration , I hooked up my TCV an when I put in Hercules with the same config mode instead of ASIO it was by far more stable and very impressive when i started going hard on the scratching. Is this weird or what?
Posted Sat 07 Apr 07 @ 6:03 pm
its weird and impossible, VDJ needs ASIO for TCV. even if you could get TCV to work on the normal Windows (WDM) the latency would be so bad scratching would sound shite.
so, dont know what you did, but whatever has happened if it works better for you, stick with it! ; )
Posted Sat 07 Apr 07 @ 9:44 pm
If you got it working well like that - make a video and Post it - lots of guys useing Timecodes on here would like any sort of help
Posted Sat 07 Apr 07 @ 10:38 pm
TCV without Asio is imposible - YOU need low latency for TCV -
Posted Sat 07 Apr 07 @ 11:00 pm
