Forum: Old versions
Topic: strange noise under bass,mid,treble...and volume
hi there.
I ve got strange noises under volume,each channels,crossfader...bass,mid and treble!Is it sound card?Or smth else!Plz help,coz u can clearly hear it after recording,at playback!
Thnx
Kissglobal
Posted Sat 07 Apr 07 @ 3:49 pm
hi
i think i have the same but mine is wenever i move bass/mid/treble/crossfader basecally anything i do while a song is playing even wen i am playing around with the next song i can hear a deep rumbling sound also i get it if i use my external mixer or my faderfox my pc works fine witth tracktor dj but i dont like using that program i think virtual dj is better but tht noise stops me from using it , when i record u can hear tht sound it cant be my sound as its a new one and it does it on my other soundcard as well. any help i would love!
I am having the same problem on both my PC's ever since the 4.3 upgrade. I hear a click click sound in the background. I got lucky with one PC this past weekend and shut it down 3 times and it went away but today it is back again. I don't understan why this program has become more unstable with each upgrade? Also, I cannot run in 1080X720 format since day 1 three years ago without the screen after an hour going black! Hey guy's what's up?
Yes i have this problem aswel, sounds like a groaning or rumbling sound whenever i use my control desk.
Im running windows XP SP2
AMD Authentic 1.4 ghz
768 ram
Soundblaster Live (for master sound) and onboard VIA AC'97 (for monitor)
Hercules MK1
Hi guys
I don't know if this is related with your problem but I also had a rumbling noise when i used my laptop, just by luck I tried another laptop with same version VDJ and the noise went away, later I find out that the AC mains adaptor was the problem, after looking around for different makes I use a HP mains adaptor and works fine, the funny noises are gone.
Good luck
