I use the Hercules DJ counsel, If I am just recording a set to my hard drive do I need to use the ASIO drivers? Is the sound marginally different I cant tell.
Posted Fri 06 Apr 07 @ 9:57 pm
its of a higher quality yes aslo asio is needed for timecode if you use that.
Posted Fri 06 Apr 07 @ 10:07 pm
you can tell the sound quality difference alot if you scratch try running over a song slowly in WDM mode
it sounds digitized.... much better in asio.
Posted Sat 07 Apr 07 @ 5:25 am
