Hi , is there anyway you can reprogram the Hercules MK2 controller, so that you could change some of the buttons or knobs you may not use , to control the gain ? Or anytips on how to get round this would be ace to know , as im finding volume changes in my mixes and there is no gain control on the controler .
Thanks Folks
Peace , love !
Shakey aka (DJ Serotone) x
Thanks Folks
Peace , love !
Posted Tue 03 Apr 07 @ 8:13 am
You must own a Professional User license in order to use a custom DJC mapper.
Posted Tue 03 Apr 07 @ 10:33 am
What are the other advatages of using the professional version ??? is it still set out to be used with the mk2 controller ?
Posted Tue 03 Apr 07 @ 5:16 pm
some are mentoned here:
http://www.virtualdj.com/products/djcedition.html
Posted Tue 03 Apr 07 @ 5:25 pm
