Forum: Old versions
Topic: Scratching sound
skillaPRO InfinityMember since 2005
I have the MKII, external mixer, TCV.
When I scratch (esp on words) it sounds digital, like a robot.
I followed all the settings on the site and played with a few but same problem.
I tried grounding to the MK2 AND to the PC, but no difference
NB latency etc is not a problem. Just the 'robot' sound when scratching
Any ideas?
Thanks
Posted Tue 03 Apr 07 @ 2:49 am
have you try on perfomance settings bar to select on scratch optimise for -quality- and on presets to put the slider on best quality?
Posted Tue 03 Apr 07 @ 4:40 pm
OK that did it. (I thought I tested all the combinations)
No other setting affects the sound in any way.
However, if I click on scratch optimise for quality it works perfect
If I click on latency, then it sounds robotic.
So I guess the setting should be on quality
Thanks for the help
Posted Wed 04 Apr 07 @ 3:47 am
