Hi, i am thinking of buying virtual dj version 4, but after talking to a dj in the local shop he tells me he is having a problem playing videos ( he gets a yellow line from top to bottom of the screen) he said he is useing version 3.4 he does not have a problem playing karaoke tracks only music videos can anyne tell me why it should do this, also will it happen with version 4
any advice would be helpful thank you
Posted Mon 02 Apr 07 @ 11:33 pm
I play videos with v4 and works smooth
Posted Mon 02 Apr 07 @ 11:54 pm
Well maybe if he came to the forum, he would get the help he needs. I can't tell what his problem is, because I don't know. I am using 4.2 and playing video without any issues.
Posted Tue 03 Apr 07 @ 12:22 am
ok i understand what you are saying ...what i am asking is anybody else having the same problem? or has anybody else heard of anybody having that type of problem ?it may be the pc he is useing ? being new to pc djing im just not sure on everything
Posted Tue 03 Apr 07 @ 12:28 am
It's happened with others on here and is usually caused by a graphics card not supporting hardware acceleration OR needing a driver update OR not having the very latest directx installed
NOTE
Many people think because they have directx9C that they have the latest version. Many do NOT know that directx updates almost monthly with incremental updates.
NOTE
Posted Tue 03 Apr 07 @ 12:30 am
Thanks for pointing that out to me i was just reading up on graphic cards in a topic called selected guides (hardware) thought it might have something to do with that
thanks again
thanks again
Posted Tue 03 Apr 07 @ 12:37 am
You can't be sure about anything. You can do your home work, and make an educated decision. It's good to ask if you don't know. I don't know shit, but my machine runs great.
Posted Tue 03 Apr 07 @ 12:56 am
I can vouch for that one. He doesn't know shit! :o)
Posted Tue 03 Apr 07 @ 1:11 am
Think ive got my head round it now, thanks to reading the topic selected guides by dj-in-norway thanks once again, just need to add up how much its gonna cost for all the right parts i need (think i might build up a shuttle with it being so compact) it only seams 10 minutes since i changed from them big old black round things ha ha
Posted Tue 03 Apr 07 @ 12:46 pm
Posted Tue 03 Apr 07 @ 9:53 pm
A Man and His Music wrote :
Don't worry about how much it's gonna cost. Your kids only need to eat every other day. If they watch the Discovery channel, they will know how blessed they are.
Love it! 'Man'.
Posted Wed 04 Apr 07 @ 1:49 am
