how i can up the quality of signal of time code cd
thank
thank
Posted Sun 01 Apr 07 @ 4:28 pm
you could try using sound forge, sony acid... or even sony vegas........... try editing in some sort of audio program..... chances are that your timecode is just too loud
i had the problem.... and based upon virtual teamers staff suggestion reduced the sound.... and now it works great
Posted Sun 01 Apr 07 @ 10:18 pm
-12 db are ok for most cd players.
Posted Tue 03 Apr 07 @ 8:33 pm
It doesn't work.
I Behringer BCD200 for external mixer and and for my time code sound card
Maybe is it this?
Maybe is it this?
Posted Wed 04 Apr 07 @ 11:31 pm
bcd2000 only supports 1 tccd input so you need another asio card for tccds but if you use tcvs you can use both channels.
Posted Thu 05 Apr 07 @ 4:02 am
