Forum: Old versions
Topic: 5.1 split channel problem
Hey,
I recently tried to hook up my audigy 2 nx usb to an external mixer, running the rear channels into one mixer channel and the front channels into the other mixer channel.
Problem is, both channels could be heard when i moved the crossfader on the external mixer to one side, and neither could be heard when i moved it across...
any ideas?
Audigy
Rear Front
Line 1 Mixer Line 2 Mixer
Both channels <------------> Neither audible
audible
Posted Sun 01 Apr 07 @ 7:37 am
if you click on the "config" button within VDJ, click on the "sound setup" tab.
On inputs it should be set to non
outputs should be set to "external mixer"
chose your soundcard from the list below.
Then chose your configuration from the list below that.
Hopefully that should sort it out!
Posted Mon 02 Apr 07 @ 3:55 am
or just open cue knob on your mixer
Posted Mon 02 Apr 07 @ 11:03 am
i've done that andy, and still no joy.
Posted Tue 03 Apr 07 @ 1:44 am
maybe try to connect all cables one more time, make sure everything is ok, i think there is some small mistake on connections it was something same for me
Posted Tue 03 Apr 07 @ 1:56 am
