It started after I had to reformat my laptop, you would think every thing would be better But no. what happens it plays ok sounds ok, but when you scroll down the left hand side to look for the next track it stops (not crashes ),not all the time but the last 2 nights I have worked its happened about 4 times in one night, so what you have to do to get it working again you have to go to config, sound setup soundcard to the dropdown menu pick sb audigy 2 (fec0) are primary sound driver which either one is not selected at the time it stops to get it work again. When you are looking for the next track there is at the top is a bit of lag on the waveform and the deck stop for a split second as you are searching can anybody help. Start a new jock job on Friday need to get it sorted quick…
Specs
Windows xp home edition sp2
Mobile sempron amd 3100+
960mb ram
Creative sb audigy2 zs notebook
Specs
960mb ram
Posted Fri 30 Mar 07 @ 9:36 am
why is my language on the website in german how do i change it back
Posted Fri 30 Mar 07 @ 9:45 am
