Hi I have 2 technics 1200 mk2 turntalbes a dell inspiration lab top and bought a gigaport ag soundcard. I hooked up the two turntables to the gigaport into the outputs white 1 red 2 and the other turntable white 3 and red 4. Then I connected my mixer channel 1 to the gigaport in output white 5 and Red into 6. Finally I have my mixer channel 2 into the gigaport White into output 7 and red into 8. I then connected my speakers to my mixer output. Is this set up correctly. When I go to config in VDJ4 and set the imputs to timecodes Outputs to external mixer and soundcard is asio. Under ASIO driver it says Gigaport Ag Asio driver. Everytime I click ok or go to asio config I get this error Error in Asio Sound Driver Not Enough Channels if anyone can help my please let me know. Thanks alot
Posted Fri 30 Mar 07 @ 1:07 am
hey,
had that problem before man...
although i have a maya 44 i reinstalled the driver...that fixed the problem for me...
does the music play right now?
also, make sure that smart lock is off (the lock thing that may be lighten up under the spinning vinyl on your monitor)...
its always these small things that are the trouble....
good luck
good luck
Posted Fri 30 Mar 07 @ 3:33 am
Umm I tried reinstalling the driver but still the error keeps poping up. The music plays out of the spearker but only when its set on imputs none not when time codes are selected. The music plays but I cant scratch or anything its not hooked up to the turntable.
Posted Fri 30 Mar 07 @ 5:21 am
What does that error mean? error in asio sound driver not enough channels? not enough channels??
Posted Fri 30 Mar 07 @ 5:24 am
On the gigaport when im playing the music only the imputs that are into my mixer are lighting up not the channels that have my turntalbles pluged in? Maybe thats whats wrong but I wouldnt know how to fix that lol Any Clues?
Posted Fri 30 Mar 07 @ 5:29 am
