jchiar wrote :
I hope this is wrong, but if anyone can verify from support,
Its NOT compatible.
On hercules FAQ site it says-
Is Hercules DJ Console Mac-compatible?
No, Hercules DJ Console only functions with Windows PCs (98SE, Millennium, 2000, XP).
We are currently studying the prospect of a DJ Console for Mac OS X, but it would not use the same hardware as the PC version.
I sure hope i am wrong. If not, anyone want a PC console?
Its NOT compatible.
It's what I suspect. I'll try to verify. Thx.
Posted Mon 02 Apr 07 @ 4:00 pm
I think what the difference is that the controls on the MAC s/w are done with Midi,
where as the PC version the control is done via usb perhaps...
There may be a workaround if we can get midi driver control ..
Posted Mon 02 Apr 07 @ 5:32 pm
