Forum: Old versions
Topic: Problem with VDJ4.2 and freezing
DeadlydPRO InfinityMember since 2004
I am Currently using a Toshiba laptop with
Processor Type Intel Pentium Core Duo T2060
Processor speed 1600 mhz
Memory Size 1024 mb
VISTA Home
I have an Audigy 2 ZS for notebook. I use the Audigy to run sound to my mixer and my on board sound card for my Headphones.
when I DJ for a certain length of time the screen freezes. The music works perfectly but I cant change anything on the screen. Its very annoying. Any Ideas???
Posted Tue 27 Mar 07 @ 5:10 pm
mzackPRO InfinityMember since 2006
many many many topics on this issue....Im not sure where to start, but there has been LOADS of tech talk on this, Im not certain the answer is a quick one.....do some searching here and you will see what Im talking about....
I use a Dell, it used to freeze on me but then I did some tweeking, as discussed in the forums and got myself a Laptop Chill pad to relieve the heat build up.....now its fine, no freezing...
Good Luck...its a hot topic here!!!
Posted Tue 27 Mar 07 @ 7:27 pm
Hi,
i used to have all sorts of problems ( screen going blank , freezing etc. Dac 3 not working) and all tweekings didn't make any difference . In the end i re-installed windows and now it is fine , no problems at all .
Posted Tue 27 Mar 07 @ 8:28 pm
