i need your help.
i use the hercules console mk2 together with vdj 4.0 and everytime i move the crossfader, pitcher or volume control (only when using the mk2), vdj creates a slight but disturbing noise like scratching over a wooden surface.
how can i solve this prob??
pls help
pls help
Posted Mon 26 Mar 07 @ 1:11 am
Try lower the performance slider preset to lower.
Also turn off safemode and overclock, and set latency to auto in same performance settings.
In VDJ 4.x you need to tweak that setting a bit, until you find the best setting for your PC.
Posted Mon 26 Mar 07 @ 1:51 am
this sounds like it might be a similar problem to mine....
here is my topic on it, it might help :)
http://www.virtualdj.com/forums/66896/General_Discussion/Strange_crackling_sound_in_crossfader__.html
DJ Turbo
DJ Turbo
Posted Mon 26 Mar 07 @ 3:58 am
Thanks für the Help I think it was the Quality preset
Posted Tue 27 Mar 07 @ 5:20 pm
