Hello! I am super, thanks for asking.
I have a problem with the 1280* skins... I have a widescreen laptop, and the normal size skins work fine, but I want the 1280* skins... so anyway, I download it and run the exe and it tells me Virtual DJ isn't installed... This happened on Jorge Rosa and Obsidian, but when I download and run, say, multipanels, it installs fine...
Any suggestions?
Any suggestions?
Posted Sat 24 Mar 07 @ 1:33 pm
If you look at the skins section - I believe those two skins where designed for ver 3.4, if you have version 4.2, then that is why you are getting the 'not' installed message.
Posted Sat 24 Mar 07 @ 4:39 pm
