can you use the serato sound card with vdj
Posted Wed 21 Mar 07 @ 10:48 pm
No, stamps are different they can work but they are not 100% compatibles, so some vdj's functions may not work.
Posted Thu 22 Mar 07 @ 8:47 pm
Hi,
I don't have one, so I'm not totally sure. But I thought that the sound card works perfectly, it's just the time coded vinyls that don't work very well.. so you'd probably want to buy some virtual dj vinyl for them.
Posted Fri 23 Mar 07 @ 10:47 am
Yes it's true, I got confused I thought you were talking about the timecoded vinyl, andytaylor125 is right I guess that serato must use a sound card that supports asio drivers so there's no problem in using it with vdj.
Posted Fri 23 Mar 07 @ 5:20 pm
ok saludos amigo
www.djnico.com.ar
www.djnico.com.ar
Posted Mon 26 Mar 07 @ 8:31 pm
