M-Audio Fast Track PRO 4x4 Mobile USB Audio will work with VDJ/TC ?
If YES, beetwen M-Audio Fast Track PRO and Maya44 witch is better, witch one performs better.
What about the Serato SL 1 Interface sound card? it will work flawless with VDJ/TC ?
Posted Wed 21 Mar 07 @ 5:25 pm
The FTP will not work for TCV because it lacks dual stereo inputs.
The Maya will work either usb or pci, I just tested the pci version.
The SSL box will work also.
Ultimately if the Numark NI00 TCV sound card becomes available, that would be the first choice if you can wait.
Posted Wed 21 Mar 07 @ 5:50 pm
It is a latency difference between SSL and Maya ? Witch one it's better on timecoding?
Posted Wed 21 Mar 07 @ 6:07 pm
If money is not an issue, the SSL box is the obvious choise. You get hardware bypass, (among other things this means you can still play regular vinyl if your computer should crash (knock on wood), (and also of course if it doesn't crash,) without repluging anything.)
Not sure about the latency, but both will be good enough. The sound quality of the SSL-card is superior, and the output signal is stronger. Also, you can run SSL on the SSL-card. That might come in handy, if for instance you are doing a gig together with another DJ that use SSL, and also you can see for yourself if it's all that it's cracked up to be.
Waiting for the numark card will give you an extra stereo-output for the sampler though...
Posted Wed 21 Mar 07 @ 6:20 pm
Thank you...for the info.
Posted Wed 21 Mar 07 @ 7:25 pm
