Is Lexicon Lambda USB Audio Interface compatible with Virtual DJ & bc2000? It will not be an issue to use bc2000 just as a controller. Thank you in advance for your help!
Posted Wed 21 Mar 07 @ 2:47 pm
cards have to be compatible with your system/ operating system......what is your OS ? i don't believe there are or will be Vista drivers for bcd2000.........
it's about how everything works together....VDJ doesn't control that aspect.....your OS and drivers do....
i have 2 cards and i had a lot of problems with one of them.....what i did was contact the maker, and they emailed me a list of tweaks (which i implemented all) and then every thing was fine ...you could encounter the same scenario
Posted Wed 21 Mar 07 @ 10:52 pm
