I made a demo CD tonight using my MK2 Controller....thats the only way I can figure out how to mix and record....anyway:
when I mix from one track to another there is a crackling noise while I slide the fader across to the next deck......it does NOT do this with my 3.4 edition.....
I may need some assistance with setting, I have no idea what a lot of those setting are, I just leave them where they were when I downloaded the program......whats the best settings????
Will this correct my "crackling" noise???
Posted Tue 20 Mar 07 @ 3:22 am
I hear in speaker that bad noise too ... i tryed 4.2 4.1 ... same noise when i move volume ... or other player ...
Posted Tue 20 Mar 07 @ 2:22 pm
go to the performances pannel
1) Move the performance slider to the left
2) Change the sound card latency : increase the latency or select "auto"
Posted Tue 20 Mar 07 @ 4:38 pm
Ok...I will give it a shot, thanks!!
Is there some kind of a mannual for VDJ, I would LOVE to get my hands on one, or is it all trial and error?
Thank god for this forum!!!!
Posted Tue 20 Mar 07 @ 5:05 pm
I tried the same versions, 4.3 and 3.2. Found out that the problem is ONLY on 4.3 not in the older versions. I tried the fix you had mentioned but nothing works. I tried various setups, nothing is working right. I love to use 4.3 but with this problem, I will have to use 3.2 for my mixing until a fix in put in place to 4.3 to work well with the Herc. Mk2 Controller.
Please help.
DJ Koolz
Please help.
DJ Koolz
Posted Sat 21 Apr 07 @ 6:26 am
It's the "latency" settings; try changing it and also disable "safe mode".
Posted Tue 24 Apr 07 @ 5:19 pm
I also have this problem when I disble safe mode it gets even worse....so this is probably a solution for most people....
Later
MikeD
Later
MikeD
Posted Tue 24 Apr 07 @ 10:18 pm
aslo check that cables are gounded and you are using a seprate plug from the laptop for the amp.
you may aslo want to use a powered usb hub
Posted Wed 25 Apr 07 @ 4:05 pm
