Forum: Old versions
Topic: power problem
when i try to connect my laptop(toshiba tecra A7) with the console.a very noizy bzzzzzzz starts.if the laptop is not plugged and only works by the battery then no problem. one time that i faced that problem after some hours was fixed by itself.anybody had the same problem?or know how to fix it?
Posted Sat 17 Mar 07 @ 2:37 pm
It is a very common problem , laptops are not earthed so therefore you need a ground loop isolator for each channel , it connects between your sound card output and console, mixer,etc , this are available at most electronic retailers and only cost a few pounds .
Posted Sat 17 Mar 07 @ 4:48 pm
docPRO InfinityMember since 2020
Or, just go to your local store and buy one of those adapters that are for a 3 prong plug into a 2 prong outlet. It it has a wire, cut it off, if it has a little tab, put some tape over it. I've been doing that for almost 15 years.
Posted Sat 17 Mar 07 @ 5:54 pm
thanks,solved it.i put some tape between the 2 prong of the plug and fixed.
Posted Sun 18 Mar 07 @ 3:50 pm
ktilakPRO InfinityMember since 2006
picture please on where to put the tape?
Posted Sun 18 Mar 07 @ 11:27 pm
Also, where does the adapter go exactly. Between wht two points of contact?
i.e., Between the strip and the wall, between the laptop and the strip, between the mixer and the wall, between the mixer and the strip, or some combination of these?
Posted Mon 19 Mar 07 @ 3:08 pm
Posted Tue 20 Mar 07 @ 4:58 pm
