I have used VDJ for quite a while and love the beat matching engine, but as of tonight when I try to beat match songs the tempo is off??
I lock in the BPM for each song and it just does not seem to stay locked on, one of the decks drifts out and I have to line it up again.....usually it stays right there until I mix the incoming song
Is there a setting off or something?
Posted Tue 13 Mar 07 @ 2:53 am
I had the same problem. what button are you using for sync. I found that if I used the sync button the skin it worked ok but when I used the shortcut it did slide out of sync, so I deleted all shortcuts relating to sync and created a new one making spacebar my sync button and not ticking the auto button in the sync settings. That fixed it for me!
Posted Tue 13 Mar 07 @ 4:29 pm
Thanks....I use the SYNC button on the skin, another thing I have been noticing, justr recently, is the BPM is 1/10 off...on some songs when I hit SYNC, the BPM does not match up....
Ex: 113.6 on deck 1 and 113.7 on deck 2....maybe thats why it causes it to "lag" behind sometimes...it is anoying especially if your ready to mix and the song is now off beat.....
Posted Tue 13 Mar 07 @ 5:34 pm
I had the sam problem but doing what I said fixed it. I am not totally sold on version 4.2R1 but 3.4 wont run right with Vista!!
Posted Tue 13 Mar 07 @ 7:18 pm
