Forum: Old versions
Topic: Remote Control MIDI connected...but not???
I have both X-Session and MAudio Trigger Finger.
I try to use or the other, it always seems that there is a 20% success rate in having it recognize it (green lite turns on after checked).
Why does it work sometimes and then you plug it in a couple days later and it won't recognize?
Posted Sun 11 Mar 07 @ 2:46 am
Any ideas? Please help. :)
Posted Wed 14 Mar 07 @ 1:15 am
Well from my personal experience you have to always be sure that you connect your devices in the same usb connectors in your computer because the computer recognizes these devices once plugged in and it seems like it automatically mapps the device to that connector. At least that is what happened to me once and ever since then I always connect my midi controllers in the same way everytime. Now do you now how to map the UC33e midi controller? Cause I've been having trouble trying to assign the samples from the sampler in VDJ to the numbers in the number pad but everytime that I press a number on the pad it will only give me the option to assign it either "absolute" or "relative" but never the "value" ? Thanks.
Posted Tue 10 Apr 07 @ 1:01 pm
