I have been considering purchasing Virtual DJ for several months. One thing that has been holding me back is a simple understanding of what hardware is recommended/supported by the company. I don't want to have to read through millions of Forum threads. Why doesn't the company offer the software bundled with the recommended hardware? What sound device does Atomix recommend/Support. Is there a simple page that Atomix produced that states: Virtual DJ supports the following hardware. Here are the Pros/Cons of each device?
Thanks,
James Borris
Thanks,
James Borris
Posted Mon 05 Mar 07 @ 11:14 pm
Reason there is not ONE setup for all, is that there are so many types of djs.
And without knowing what you want, its hard to recommend.
A bundle?
Get Numark VirtualVinyl (same software as VDJ), that includes a soundcard and timecode vinyls, to control the software on regular turntables.
BIG PICTURE
If you dont want to use turntables, VDJ works with almost any soundcard, and as a supplement, many use midi controllers (instead of or as companion with turntables)
For none timecode control, get any soundcard you like, that has two stereo outs.
A bundle?
BIG PICTURE
Posted Mon 05 Mar 07 @ 11:24 pm
for more good contolers check :)
https://virtualdj.com/forums/59875/Hardware_Technical_Support/ultimate_guide_to_controllers.html
Posted Mon 05 Mar 07 @ 11:27 pm
