Forum: Old versions
Topic: TCV and Sound Blaster X-Fi
oppofixHome userMember since 2006
Hi everybody, I explain my problem.
I use U46DJ with TCV and VDJ4.1, everything works fine.
I want to improve sound quality, and I have a
Creative Sound Blaster X-Fi Extreme Music,
the audio sound for MP3 is excellent.
What I would like is to send the TCV signals
directly to the U46DJ inputs, getting the two
output channels from the X-Fi card, (to send directly to the mixer).
For this reason i use ASIOxALL v.2.7; VDJ recognizes the TCVs signals,
but only 1 output is sent out from one of the 3 jacks of the X-Fi.
Maybe I have to modify some configuration on VDJ register?
Here's what appears on ASIOxALL page:
U46DJ Audio Driver (Running)
U46DJ Ch 12 (Running)
OUT: 2x 22.0-192kHz, 16 bits (Not Running)
IN: 2x 22.0-192kHz, 16 bits (Running)
U46DJ Ch 34 (Running)
U46DJ Ch 56 (Not Running)
IN: 2x 22.0-192kHz, 16 bits (Not Running)
Creative X-Fi Audio Processor (Running)
IN: 2x 0-192kHz, 32 bits (Not Running)
OUT: 8x 0-192kHz, 32 bits (Running)
Asio Buffer Size=512
Use Hardware Buffer = Unchecked
Always resample 44.1 kHz <-> 48 kHz = Checked
Force WDM Driver to 16 Bit = Unchecked
Thank you for any Help.
Fabrizio (Italy)
Posted Fri 02 Mar 07 @ 8:59 am
Hi, anybody can help me?
If this will work, i'll buy the program, since now i'm using the demo version.
Thanks and bye.
Posted Sat 03 Mar 07 @ 2:49 pm
Hi there..
Its possible using Asio4all yes...
You need to select the inputs and outputs at the "virtual" asio4all driver, and choose the Asio4all as soundcard in VDJ.
But why dont you use Soundblaster X-Fi for both inputs and outputs? I bet that would work better....
Posted Sat 03 Mar 07 @ 3:49 pm
Thank you for the answer.
The configuration that i showed you in the first message works fine
for what concern the two inputs and one output.
The problem is that i only get one output from the Line Output 1
of the card, and i don't know how it's possible to get the 2nd output
from the other two output lines 2 and 3.
- Maybe, have i to use two X-Fi cards?
Consider that there is only one input in X-Fi card.
Thanks a lot, Fabrizio
Posted Sun 04 Mar 07 @ 9:59 am
What do you get at the 1 output at the X-FI card? Both sides (decks) in VDJ?
If so, did you select "External mixer" in VDJ soundcard output selection ?
Posted Sun 04 Mar 07 @ 1:27 pm
Yes i selected "External Mixer" and at the Output 1 i get the stereo sound
of the first deck. From Output 2 or 3 doesn't come out any sound,
even if i run with a song on deck 2.
Fabrizio.
Posted Wed 07 Mar 07 @ 1:44 pm
