HELLO I AM HAVING AN AUTO MIX PROBLEM, IM USING 4.2 WHEN IT GOES TO MIX ON AUTO IT WILL CUT INTO THE MIDDLE OF THE NEXT SONG OR THROW THE CUED SONG OUT AND LOAD THE NEXT SONG UP IN MY PLAY LIST I TALKED TO OTHER DJS AND THEY SAID THEY ARE HAVING THE SAME PROBLEM I REALLY NEED TO KNOW HOW TO FIX THIS PROBLEM ASAP THANK YOU
Posted Wed 28 Feb 07 @ 12:08 am
hey can you help me real quick
Posted Wed 28 Feb 07 @ 12:17 am
This has been addresed mulitple times - do a forum seach particluarly in "bugs"
simple answer
1) update microsoft directx drivers to very lastest and current.
2) turn off safemode , and overclock in performance tab config menu.
3) update to windows media player 11 (not nesseary but as long as you're updating)
this fixed automix on my system.
I believe DEV team is working on a patch or program update - but after the MAC version.
simple answer
Posted Wed 28 Feb 07 @ 12:25 am
thanks ill try it dj
Posted Wed 28 Feb 07 @ 1:46 am
If you turn off safe mode, the prelisten with your headphones sounds terrible.
Anybody else having this problem?
Posted Sat 10 Mar 07 @ 2:31 pm
blimey dissable those angry caps
Posted Sat 10 Mar 07 @ 3:56 pm
