Hi all,
I have a problem with my bcd2000, i connected it with the vdj with 2 soundcards one is the bcd2000 and the output of bcd2000 there is a sound problem the sound is NOT clear..
BUT the first 10 minutes the sound is clear and the its starting to get worst..
Anyone have an idea?
Thank you in advance!
Posted Sun 25 Feb 07 @ 3:19 pm
ensure you have the lastest demo
https://virtualdj.com/download.html
Posted Sun 25 Feb 07 @ 6:45 pm
i have vdj demo 4.2 isn't this the latest one?
Posted Sun 25 Feb 07 @ 8:50 pm
look for 4.2r1 and check that on proformance options you have fast
and "autolatency" selected and the boxes safe and overclock turned off :)
Posted Sun 25 Feb 07 @ 11:17 pm
still not working.. anyone has any advice?
I am planning to buy vdj i found it very usefull but now when my console is not working with it i don't what to do? how can i really fix it? can it be fixed?
Posted Sun 25 Feb 07 @ 11:30 pm
https://virtualdj.com/blog/juliocqb/
check this blog =D
check this blog =D
Posted Sun 25 Feb 07 @ 11:34 pm
I have done everything as said but still nothing...
P.S I am using it as 2 soundcards a bcd2000 and the soundcard of my pc... sometimes the headphones are doing this silly noise, and sometimes the master output.. But still this is happening after 10 minutes
Posted Mon 26 Feb 07 @ 1:29 pm
Why are you using 2 soundcards and not just one (BCD2000)?
Posted Mon 26 Feb 07 @ 1:49 pm
use just the bcd as a sound card, but do not pick the bcd icon on the sound card section, , choose BCD ASIO and pick the computer and the phones on input put none and then you'll be ready to go, do not forget to take a look in to my blog for more info.
Dj Quintana
Posted Mon 26 Feb 07 @ 3:30 pm
Dj Quintana thank you! I have done it!...
Is there any map avaible that can drop songs using the jog wheel and analog input a/b without using the mouse button?
Posted Mon 26 Feb 07 @ 5:15 pm
In order to download the BCD mapper you have to buy the software. Enjoy the demo version and if you're happy with it then .. http//virtualdj.com/purchase.
Posted Mon 26 Feb 07 @ 6:55 pm
you got the answer my friend ;)
Dj quintana
Dj quintana
Posted Mon 26 Feb 07 @ 9:11 pm
